  4. Battery drain
Battery drain
36 Posts 11 Posters 396 Views 3 Watching
    RouteXperts
    Yes we all know about the problem caused by the Here maps. My phone has picked it up to and wants to put in deep sleep, not
    Garmin XT (almost in the cupboard)
    Samsung S20FE mounted on a Quadlock and using Android Auto in my car
      M. Schrijverundefined Offline
      Do you know what causes the battery drain?
      Personally is suspect recalculation while riding is the main cause of the battery drain.
        RouteXperts
        @M-Schrijver as far as I know it's caused by the Here maps. The team is talking to Here for a solution but it's a slow proces
          Yes, i know.
          But i've noticed something.
          When you follow the route exactly as planned in advance. And because of this no recalculation are needed. The battery usage is almost on par with other apps like Google maps, Waze or TomTom Go.
          But when you have a bad route which needs multiple recalculations especially within in few kilometers. The juice is sucked out of the battery very quickly.
          The other day i went from 90 to 80% in two hours. I had 2 recalculations in this time. Then i went from 80 to 50% in 30 min. In this period i had multiple recalculations in a small area (roads closed, wrong roads, etc).
          The last part was 1 hour with one recalculation and went from 50 to 44%
          My first route this year was a very well known route (for me). The route was therefore exact. It is a 4 hour ride. No recalculations needed. I went from 100% to 95% in 4 hours. Still a bit high consumption but no problem for a riding a whole day.
          Drabslabundefined Con Hennekensundefined GT JWRundefined 4 Replies Last reply
            Yes, i know.
            Drabslabundefined Offline
            Drabslab
            @M-Schrijver I more or less stopped using Next because of this battery issue. I don't plan burning my phone with this tool, and I don't like ariving somewhere with an empty battery, or riding fearing that my phone will shutdown.
            Still strange that this is caused by Here. Are there massive complaints on the net about the Here apps as well?
              I don't know. I want to try the Here app also. Just for A to B and see what it does
              Jack van Tilburgundefined 1 Reply Last reply
                Jack van Tilburg
                wrote on last edited by Jack van Tilburg
                @M-Schrijver said in Battery drain:
                I'm curious about your experiences if you start using it.
                I use it regularly and have no problems with battery drain or a warm iPhone.
                  RouteXperts
                  @Jack-van-Tilburg it is for sure better than before but as you can see there are still some issues. I hope that @Corjan-Meijerink van solve it with Here. Still hopeful
                    Yes, i know.
                    It is not the recalculation, it is the rendering of the map, that already has been established. Is far as I know there have not been any claims before that indicate that recalculation has an influence. Recalculations are usually very short, so I don't think that is it.
                    @Drabslab said in Battery drain:
                    Some phones suffer more from it than others. I suspect mainly higher-end phones suffer more. My daily Pixel 8Pro can keeps up with cable-charging, but not with wireless charging. On my Bike I use a CAT S52 and that one has no problem at all, charges almost as fast as always on the bike. Using the app "G-CPU" is saw that the cpu cores get maxed out while dragging the map on the screen. The rendering of the map is done by functions of the HERE SDK the app makes use of.
                    Saillant detail: HERE's own Here WeGo app suffers from the same problem (is built on the same SDK)...
                    Streetpilot 2610 / Zumo 660 / Zumo 395 / CAT S52 + MRA app
                    M. Schrijverundefined Drabslabundefined 2 Replies Last reply
                      @Con-Hennekens said in Battery drain:
                      I did not know that.
                      But why is the battery usage a lot higher when there are many recalcultions in a route compare to no or nearly no recalculations.
                      Map renderings are not that different for a whole day/trip
                      A little sidenote. The day i had a high battery usage. The Data usage was also enormous. Almost 500 MB for a 180 km ride. That's idiot. This means a 10 day holiday could cost me 4-5 GB's
                      The day with a low battery usage had also a lower data usage. Around 80 MB for also a 180 km ride. Still a high usage to my opinion. TomTom Go uses around 10 MB for the same route. But data usage is a different topic.
                        I have never noticed that, nor have there been others that mentioned that as far as I remember. You must consider that a recalculations take place in a second. How much energy would that consume in such a short time?
                        Rendering a map which continuously moves draws power continuously. Albeit in the HERE SDK too much.
                        I have not been paying a lot of attention to data consumption lately. But I know from a 6 day trip last year that it was almost negligible as long as you have downloaded your maps for offline use. If you have not done that, 500MB for live caching of map data sounds like a lot, but not impossible I think. I think if you keep driving in the same areas, the data comes out of cache. Therefore you will likely not need 4 GB of mapdata for a 10 days holiday. But I can't be sure of that.
                          Yes, i know.
                          GT JWRundefined Offline
                          GT JWR
                          @M-Schrijver Good for you if that seems to work for you! That most definitely has not been my experience at all. Once I have a pre planned route before hand, I typically follow it to a tee....battery drain is crazy nuts....🤷
                          Andrewundefined 1 Reply Last reply
                          • GT JWRundefined GT JWR
                            Andrewundefined Offline
                            Andrew
                            @GT-JWR Had the same problem yesterday with a 300ml route phone was on 100%Charge at start plugged into power on the bike, only lasted for about 130mls before it switched itself of as it was flat.
                            GT JWRundefined Andrewundefined 2 Replies Last reply
                            • Andrewundefined Andrew
                              GT JWR
                              @Andrew yep...my iphone hasn't actually turned off, but it goes into a power safe type mode where the screen goes so dim, I might as well just turn it off.....for 'critical' bike trips (where I am leading), it means I have to download the routes to my XT and use it. Really hope this issue gets resolved soon.
                                Drabslab
                                Hai Con,
                                My phone is not a high end phone. Its a simple Samsung A-32.
                                • Drabslabundefined Drabslab
                                  Hai Con,
                                  @Drabslab, Okay, good to know. So there must be other factors in play.
                                  Arno 0undefined 1 Reply Last reply
                                    Arno 0undefined Offline
                                    Arno 0
                                    I might be wrong but understand that a few weeks ago there were a number of days planned together with Here people to invest and hopefully solve the battery drain issue. Does anybody know the results because I haven't seen any information yet.
                                    • Arno 0undefined Arno 0
                                      administrator
                                      @Arno-0 they are working on it and we have reported further feedback and provided more information. Is it painstaking? Yes. Am I doing everything in my power? Yes. 🙂
                                        Arno 0
                                        @Corjan-Meijerink Thanks for the update. I'm convinced that you do everything that is possible to solve this issue but waiting is always difficult 😉
                                          Andrew
                                          @Andrew Have found information on line when a phone gets down to a certain cold temperature it will stop charging to protect the Battery. Here in England I was out in 8 deg Celsius so the wind chill factor would of been a lot colder as phone is out in the open on a mount, am wondering if this is some of the problem along with excessive Battery Drain.
                                          GT JWRundefined
                                          GT JWR
                                          Jack van Tilburg
                                          Drabslabundefined
                                          Drabslab
                                          Arno 0undefined
                                          Arno 0
                                          Simon Ferrariundefined
                                          Simon Ferrari
                                          Andrewundefined
                                          Andrew
                                          Mario Ivancicundefined
                                          Mario Ivancic
                                          • Newcomer
                                            Guzzistundefined
                                          • Issues with Search in CarPlay
                                            UltraStarundefined
                                            UltraStar
                                          • Route app werkt helaas nog niet hoe ik het graag zou zien.
                                            P van der Meulenundefined
                                            P van der Meulen
                                          • Over heating phone?
                                            GT JWRundefined
                                            GT JWR
                                          • iOS crashing with Silverfox B8J and panning not working
                                          • Uploaden naar Zumo lukt niet vanaf iphone
                                            Ad Vundefined
                                            Ad V
                                          • Route recording on CarPlay.
                                            HighPeakRiderundefined
                                            HighPeakRider
                                          • waypoint name on carplay
                                            Cristiano Repettiundefined
                                            Cristiano Repetti
